Sync and save data?
  • 5 replies
  • 35 views
  • Last reply by Paul Kossa
I'm trying to sync data from my computer to my phone. When I go to the settings, there is NO "sync and save data " option on my phone. So, how then do I sync and save?
All Replies (5)
Hi Paul
Do you see your email address listed in the Firefox for Android menu? If so, select this and you will be taken to the Firefox Sync settings on your mobile device.
Doesn't have my email, but it does show my name (first and last). When I clicked on that there was a "sync now" label.
Hello,
I am glad to hear that your problem has been resolved. If you haven't already, please select the answer that solves the problem. This will help other users with similar problems find the solution.
Thank you for contacting Mozilla Support.
Im having this same issue, but tapping "sync now" doesnt do anything
I think it MAY actually be working (but it doesn't give you any confirmation that it synced). There was a brand new bookmark that showed up on mine, so it must have connected.
